Weather Stripping Leaking
Old 02-17-2009, 10:47 AM
blades11b's Avatar
Default Weather Stripping Leaking
Alright guys i just got back from a trip and my weather stripping is leaking a bit ive noticed over the life of the car its gotten a little worse this i discovered because i only come home ever 6 months (im in the army and im usually deployed) and the entire time im gone the windows are up here in the dessert heat so when i got back i roled the windows down and i could definatly tell that where the window seats against the T top rubber its pushed it up and pretty much formed it in the up position i figured while im at it i might as well do all the weather stripping so anyone know where to get T top rubbers and how to replace them? and where to get all the other weather strippng?
Old 03-05-2009, 11:07 PM
99SSAGUI's Avatar
I am on the same situation. hope someone here can help
Old 03-05-2009, 11:55 PM
blades11b's Avatar
i found out you can get the weather stripping for the t tops and doors from GM..... hefty price though like 300 dollars for one side for t tops and door together
Old 03-06-2009, 12:27 AM
Greekey's Avatar
Tell Gm to F*ck off
Old 03-06-2009, 12:33 AM
Taken4granted's Avatar
GMpartsdirect.com it's about $170 +/- shipped. I'm in the same boat
Old 03-06-2009, 01:48 AM
ddm3889's Avatar
try putting some vaseline on it and let the strips absorb it, they should liven up a bit
Old 03-06-2009, 07:46 PM
nemss1's Avatar
^^^x2
Old 03-09-2009, 12:58 AM
blades11b's Avatar
good idea ill give this a shot
Old 03-10-2009, 08:33 PM
TKTMAGNT's Avatar
dielectric grease works well too
Quick Reply: Weather Stripping Leaking
