Aftermarket balancer for TA spinning 7k?
We're internally balanced, but if you want to play it safer then you could add in a key to the factory hub. Stock motors can easily do 6500, so I'm kinda thinking 7K isn't outside the limits of the factory hub.
Moderator
I spoke to Thunder Racing about this today since the Pioneer keyed hub is out of stock, I mentioned the Jegs peice and he said it looked identical to the Pioneer keyed crank hub. Although on Jegs site, they mentioned you can only use their brand Harmonic Balancer Pulley with it.
