nitto nt555r
Old 02-17-2009, 07:35 PM
buckner01's Avatar
Default nitto nt555r
has anyone used the nitto drag radial, do they grab well, or should i spend the extra and get the m/t streets, im not gonna use them on the street so street manners dont matter. do they need heated a lot, any info would be helpful
Old 02-17-2009, 07:38 PM
99FormulaM6's Avatar
search would be your friend in this case... But to answer your question, they grab OK. They are not the best drag radial, but they better than most street tires. If you are not using them on the street, than get a different tire. Nittos are a great street drag radial, but if you only need a great drag radial, then go with the M/Ts or M&Hs
Old 02-17-2009, 07:51 PM
buckner01's Avatar
gotcha appreciate it
Old 02-17-2009, 08:15 PM
highheat99's Avatar
i loved them. i used them at the track and they gripped good and i didnt even heat them up good.
Old 02-17-2009, 10:19 PM
Jeff400w's Avatar
If your not using them on the street,go with the M/T's.
Old 02-17-2009, 10:27 PM
69TA's Avatar
what Jeff400W said^^^
Old 02-17-2009, 10:56 PM
tspence45's Avatar
I love my Nittos. They worked well for me at the strip. I was hooking too hard, and bogging on 2.5k-3k launches. But, I still would've gone M/T's or some other if I was using them for track-only. I just wanted a DR that would give me long life for DD'ing, and not be too bad in the rain.
