Stock pump will support what horsepower
Couldn't find it doing a search, I need to know if the stock pump will support my new mods on my 98 TA:
Ported throttle body
LS6 intake
46 lb. injectors
218 214, 112 lsa cam
Pacesetter Long tubes
TSP True Duals
Tune
Will the stock pump be ok with the giant injectors, or do I need to upgrade.
BTW- I'm out of money!!!!!
LS6 intake
46 lb. injectors
TSP True Duals
Tune
Most people say the stock pump is good to around 475 fwhp.
I'm assuming you mistyped on the cam specs. I'm guessing you mean 218/214 @ .050 on 112 LSA. If the cam is as mild as it think it is the stock pump will be fine, in fact. The stock injectors would be fine too. The size of the injectors has little to do with the pump requirements. Pump requirements is more determined by the how much fuel the motor will need.
Re'
Re'
