Koni adjuster carpet questions
Since I just installed konis and stranos, I dont want to have to remove so much stuff just to adjust the rears. Does anyone have a pic of the rear carpet cut out so that they can adjust it without having to remove the interior.
unless the carpet has been replaced, i cant imagine why you cant find it. if you put the carpet back into its original place after installing the shocks, just feel around the area where you had to tighten down the nut on the top of the shock. its in that exact area, about a 3x4in section of carpet. just feel around the carpet, and you should feel the perforations. the only reason i can think of is either the rug is skewed off position, or sometime before you bought it the rug was replaced with an aftermarket.
