A good cam choice for new heads?
I just got my heads back and I wanted to double check cam recommendations. I'm running 5.7 ls1 241 heads with the patriot dual gold springs, 2.02 and 1.57 valves, valve drop is .105 and .135, and they are milled .030. These flow extremely well! I am thinking about running the 90/90 and have nearly all the bolt-ons. I have 42lb. injectors but I will be downsizing if needed and a tci 3500 which I will might trade out as well. I might run a dry 150 or less shot. I currently have a comp 222/222 so I want to go bigger but remain streetable. Looking for usable power not just peak #'s! I want something that will fit with my setup!
Thanks!
Chris
Thanks!
Chris
LS1Tech Premium Sponsor
Give us a call we have tons of camshafts in stock & can help spec you a custom camshaft for your application.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
