what should i do forged 347 or a brand new tsp 370
Ok i been doing alot of thinking and im still not sure at all. Should i reuse my block and and buy forged pistons and rods and my block has around 100k on it. Or should i just buy a new tps 370 for around $3000 and have a dependible motor to spray. And im planning on camming it adding some spray i do alot of frag racing. And how much power difference am i looking at for both motors cammed?
Just my personal preference for a forced induction motor I would do smaller cubes. If im going to do a larger cube motor why would I want/need nitrous unless Im trying to go single digits then it's a different case If bigger cubes is what he wants just build a high compression ls2 402 or a high compression 427 N/A or a iron block 408. With a nicely built trans/stall and rearend plus tire I can see high tens N/A maybe even mid 10s who knows.
LS1Tech Premium Sponsor
Looking at your choices I'd probably take the 370 with the larger bore. That being said saving for a 408 would be by far your best plan!
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
i`m building a 370 right now. the reason being that when i sold my ls1 block i bought a iron block and crank for about 200 more than i sold my old one for, after that the build cost was the same (or about) and i plan on spraying it alot so for me it just seemed like the better choice. now i`m beating my brains out trying to figure out heads but i think i`m leaning torwards trick flow 220 as cast heads
