Small Block & Big Block Chevy Specific - 1.5-1.6 roller rockers?
View Full Version : 1.5-1.6 roller rockers?
1994t/a
02-18-2009, 08:29 PM
Hey guys...im about to buy a set of roller rockers.im thinking about getting a set of 1.6's but i was curious about is if there is a noticeable diffrence between the two and if it would affect my cam timing any?It going on a 355 with a comp 270 cam,flat tops,and set of S/R torquer heads....thanks for any help
87silverbullet
02-19-2009, 10:15 AM
You will get a very little noticeable seat of the pants feel from them. Your time slip will tell you the difference. You will gain a little more duration out of your cam with them and of course you will gain the lift. Make sure you springs/heads can handle the extra lift.
boogeyman
02-21-2009, 07:16 PM
typically u gain .5 degrees duration per .1 increase in ratio on rockers just beware that your valve pockets may not have the needed clearance for your valves w the increased lift
