quick question regarding histograms in HPT (dialing in MAF)
Old 02-19-2009, 12:39 AM
sidewayz28's Avatar
Default quick question regarding histograms in HPT (dialing in MAF)
Hello, its actually a quick question. Im trying to dial in my MAF and im checking out my data from the log, and i was just curious, are you supposed to have negative values for your MAF - AFR error histogram?
i can provide a scan, tune if you'd like..
thanks in advance!
Old 02-19-2009, 12:43 AM
Randy@RaginRacin's Avatar
Negative for the the Maf. Or are you logging fuel trims. Email me the log. I'll take a look at it for you. raginracin@gmail.com
Old 02-19-2009, 01:03 AM
sidewayz28's Avatar
thanks man, on its way!
Old 02-19-2009, 01:44 AM
sidewayz28's Avatar
after doing a little research, i shuold probably tune the VE before MAF?
Old 02-20-2009, 08:20 PM
98Camarod's Avatar
That is correct. Do you have a wideband installed?
