847, stall is def. needed?
Old 02-19-2009, 06:57 PM
camar0corey's Avatar
Default 847, stall is def. needed?
With the GM847 is a stall absolutely needed? My friend is looking at this cam, but I'm trying to figure out what all he would need. He has a stock stall right now but he thinks he has 3.73 gears though.
Also what valve springs will work? Like I said just trying to figure out what all he would need.
Would smaller cams like the 227 and hot cam need a higher stall?
Old 02-19-2009, 07:01 PM
CamaroRacing12's Avatar
probably dosent need a stall, but im sure a stall will benefit his setup greatly
Old 02-19-2009, 07:24 PM
ss.slp.ls1's Avatar
Yes! You would want to change the stall for any cam...yet alone a big cam like a GM847. I think with a stock stall the car would feel very sluggish. I would look into a set of PAC 1518 springs for that cam.
Old 02-19-2009, 07:29 PM
96lt1m6's Avatar
i don't think it will idle in gear without a stall......
3500-4200 would be a nice complimenting converter
Old 02-19-2009, 07:43 PM
OWN3D BY MY PROF!
Beaflag VonRathburg's Avatar
The car probably wouldn't even operate without a stall. It would be almost undrivable because of how sluggish it would be.
Old 02-19-2009, 08:07 PM
Thanks guys, I've talked it over with him, probably going to be sticking with a stock cam for now. What about the smaller cams like the hotcam? Will it have the same issue?
Also he needs longtubes and a ORY, so if anyone has these items laying around let me know.
Old 02-19-2009, 08:11 PM
ss.slp.ls1's Avatar
Your buddy definitely should not be making his cam selections by the suporting mods required. That's backwards. Ask him how much power he wants to make, or how fast he wants to E.T., and then more importantly, what's his budget and go from there.
Old 02-19-2009, 08:17 PM
96lt1m6's Avatar
to be honest, a STOCK cammed Lt1 benefits from a stall 26-2800 optimum would be more especially with a larger cam. with all the posts about this it should never be an issue......
tell your friend to forget a cam if he does not have all the bolt ons yet
Old 02-19-2009, 08:39 PM
I don't think he has a power goal in mind, I think its more sound related in his case. He said he could get a 847 for $150, I then told him let me figure out what else you are going to need. Specifically what springs and a converter, I've been around long enough to figure the rest of the equation out.
Budget is a issue in his case though so I think for now no aftermarket cam will be the best route. Def. doesn't have funds for a converter.
Thanks, I think I've got him sticking to a stock cam for now, we are just going to try to take care of that knocking shortblock and get him some longtubes.
This is the black Formula I posted video of about a week or so back.
Old 02-19-2009, 08:43 PM
ss.slp.ls1's Avatar
Yeah, just do all the bolt-ons first. But a knocking motor? Better get that taken care of.
Old 02-19-2009, 08:46 PM
Yeah he is lining up another short block at the moment and looking for longtubes and a ORY.
Whats funny on the knocking motor is it has been knocking for a long time now. I'm just hoping it holds together long enough that I get my car back off jackstands so I have somewhere to work on his.
Old 02-19-2009, 08:51 PM
ss.slp.ls1's Avatar
Well if you are installing a new shortblock, there is no better time then now to install a cam.
Old 02-19-2009, 08:54 PM
Yeah, but it just won't be in his budget for a converter, springs, depending on if the shortblock came with kinda fresh lifters, his have 167k on them, well it would be outside his budget. I understand it would be a ton easier with the motor out of the car, but I guess he will just have to be patient.
Old 02-19-2009, 09:05 PM
phirepower's Avatar
a stock stalled 847 cammed car would make little sense... a smaller cam would out perform it easily.
Old 02-19-2009, 09:08 PM
myltwon's Avatar
I've seen decent size cam guys on a stock convertor, not exactly a beast from a dig but it's doable i guess
Old 02-20-2009, 06:55 AM
96capricemgr's Avatar
The 847 needs o rev too high for the stock shortblock anyway.
Far as stall, I did a ZZ4 cam which is like 24 degrees smaller on the intake than the 847 and still I saw no gain till I properly supported it, got .7 or so from a 2800 stall on STREET TIRES. In other words a cam without a stall does not work well. My car drove wonderfully, guys who knew about the cam swore it passed for stock in sound and manners.
It ran a best of 14.9 cam only(sad I know), then as I gave it slicks, stall and headers it dropped to 13.2 without ever taking off the valve covers again. That is how important it is to have supporting mods for a cam.
Old 02-20-2009, 07:43 AM
myltwon's Avatar
actually 847 runs out of steam before most smaller cams and doesn't rev high since the heads can't support it
avg gm847 dynograph I've seen peaks around 5800-5900rpm, whereas my cc503 was still making power at 6400rpm
Old 02-20-2009, 01:19 PM
blackz93's Avatar
What?!
Old 02-20-2009, 09:26 PM
myltwon's Avatar
what do you mean "What?!" ?
Old 02-21-2009, 12:34 AM
blackz93's Avatar
That's EXACTLY what I meant! Your post doesn't seem accurate.
