Midwest fabbed 9" install...
Old 02-19-2009, 08:00 PM
Bad30th's Avatar
Default Midwest fabbed 9" install...
My Midwest Chassis fabbed 9" has arrived, so here's the install writeup !
I got the backbraced 9" housing
3:70 Motive gears
TruTrack
31 spline Moser axles
powdercoated black
fill cap
Strange chromoly driveshaft
chromoly torque arm (short)
crossmember w/ driveshaft loop
10 bolt coming out...
Rob (Bad30th)
Bad30th's Avatar
As of now tonight I already have the complete parking brake assembly on both sides, rotors and brake caliper brackets put on the new rear, and replaced the wire loom on the TCS wiring harness.
I have new Prothane sway bar bushings and end links to put on, and have done lots of cleaning/polishing while the car was down...
I'm trying to get the little stuff out of the way before Saturday (I have an f-bud coming by to help with the install).
ABS/TCS sensors are now installed (took a little finesse)... Test fit the crossmember, plenty of clearance for the exhaust.
I also picked up the 4 grade 8 30mm 1.25x8mm bolts and washers for the crossmember since I sent mine off with my old torque arm.
More to come !
Rob (Bad30th)
Old 02-19-2009, 09:00 PM
somws6bird's Avatar
Very nice pics. That rearend looks indestructible.
Old 02-19-2009, 11:10 PM
madclown's Avatar
Great pics. Thanks for sharing, hope there will be more following the install process. Looks really nice.
Old 02-20-2009, 07:37 AM
TNTramair's Avatar
lookin good. i ran into a slight issue while installing mine this past weekend so here's a heads up...looks like your running Bilsteins, i actually had to enlarge the shock mount holes on the rear cause my Bilsteins wouldnt go through. of course thats not a big deal but when i was in the process of installing it and it was being balanced on a trans jack 4 feet off the ground, it kinda sucked..lol. you may not have this problem but just in case ya do.
Old 02-20-2009, 09:07 AM
Bad30th's Avatar
Thanks for the tip - yep they're Bilsteins (good eye, heh) - I'll check the clearance on the shock bolts.
I will get more progress made tonight after work, but most of the work will be Sat AM. I'll be sure to post pics/progress.
Rob (Bad30th)
Old 02-20-2009, 10:18 AM
Dave 96TA's Avatar
Looks like crap. Just hand it over to me!
jk very nice. wish i had the money right now, feels like i'm on borrowed time with the 10 bolt.
Old 02-20-2009, 10:52 AM
dschmittie1's Avatar
Looks good I can't wait for mine to ship.
Old 02-21-2009, 11:50 AM
madclown's Avatar
Me Too!!!!!
Old 02-21-2009, 05:01 PM
DiabloFormula's Avatar
Looks awesome man........you def. didn't go wrong with a Midwest.
Old 02-21-2009, 08:29 PM
SoxXpupPeT's Avatar
i really want one of those! im saving my pennies for one. hopefully this spring/summer. how much did you pay for everything ? if you dont mind me asking
Old 02-21-2009, 08:48 PM
Bad30th's Avatar
More pics from today's install !
I need a different yoke on the driveshaft to fit the the 4L80E but Eric (who answered his phone on Saturday night BTW, awesome customer service !!) confirmed I needed a different one and is sending the correct one which should arrive by Tuesday.
Everything is installed and just needs to be adjusted to get the driveline angles straight once the driveshaft is all good to go.
Rob (Bad30th)
Old 02-21-2009, 11:32 PM
SoxXpupPeT's Avatar
im so envious! that looks great! if i got one id be so tempted to get it in red. but then everyone would notice it
Old 02-22-2009, 12:38 AM
madclown's Avatar
I paid $3690.00 for my setup. I hope to have it soon.....Bad30th, that install looks very good. I notice you do not have adjustable LCA's and put them in the second hole from the bottom on the relocating mounts. Did you just use that for a starting point or was that the best for the pinion angle?
Old 02-22-2009, 08:50 AM
Chris05ssTruck's Avatar
Looks good.......now if only mine would finally show up
Old 02-22-2009, 08:52 AM
Bad30th's Avatar
I just used the 2nd from the bottom LCA hole as a starting point - seems like most people have theirs set there. Once I get the driveshaft in we'll see what the angles look like and whether we need to move the LCA's to a different hole or not.
Everything went together pretty smoothly, the hardest things were getting the brake lines bent to fit and connected, and getting the shock bolt holes reamed out for the larger Bilstein shock bolts. All in all everything went very smoothly so far.
Rob (Bad30th)
Old 02-22-2009, 03:47 PM
Blacked_Out_SS's Avatar
looks good man..... i get to do this same thing soon..... i hate 10 bolts
Old 02-23-2009, 07:28 AM
TNTramair's Avatar
Rob (Bad30th)
so it wasnt just me...lol.
rest of the install looks great. these things look awsome under our rides. hope it performs as well as it looks when im ready for the track..lol.
Old 02-23-2009, 07:46 AM
spaz1's Avatar
Looks wicked man I can't wait to get one of these in my car.
Old 02-23-2009, 11:02 PM
69TA's Avatar
Looking good.....How is the clearance by the gas tank and exhaust?
Quick Reply: Midwest fabbed 9" install...
