Port my stock heads or buy new?
Old 02-19-2009, 08:13 PM
VLANDER005's Avatar
Default Port my stock heads or buy new?
I have about 1500 dollars to play with this tax return. I already have a lid, long tubes, ported TB, msd wires and will be getting a good tune this spring. I am also going to install an ls6 intake. Should I have my heads ported and polished, or just buy new heads? If so, which heads do you recommend? I am looking for 400+ hp at the rear wheels.
Old 02-19-2009, 10:43 PM
mtuggle86's Avatar
Id port the stock heads theres cars around here pushing 500rwhp with ported 241's then take the money you save and put it towards a ls6 intake or a cam
Old 02-19-2009, 10:50 PM
SS02's Avatar
If im not mistaken.....youll probably need a tune if you mess with the heads. IM sure someone will be in hear to chime in on that.
Old 02-19-2009, 11:03 PM
ZMONSTER!'s Avatar
I would definetly like to see what a set of ported 241's with bigger valves could do. Im contemplating doing the same thing with my stockers so that I can fit a bigger cam. I have seen a few guys with good results....
https://ls1tech.com/forums/generatio...p-p-241-a.html
Thread I started basically asking the same thing.
If you do get your heads done I would recommend talking to serious drag racers in your area and who you think you should send your heads to, id be surprised if there wasnt someone local to you that could do an excellent job for cheaper than shipping them elswhere.
Old 02-20-2009, 06:01 AM
VLANDER005's Avatar
There not many machine shops in my area that could rework these heads. Anyone know who I could ship them to on the east coast? I am located in upstate new york. I am already running an aftermarket comp cam, I'll get the specs on here later. What could I expect for a gain at the rear wheels with the ported heads, ls6 intake and a good tune? Ontop of my lid, long tubes, msd ignition, ls6 oil pump on 93 octane?
Old 02-20-2009, 08:36 AM
ZMONSTER!'s Avatar
Isnt bret bauer back east? The T4P dart guy?
Old 02-20-2009, 09:45 AM
mtuggle86's Avatar
sorry I dont know anybody that will port heads out there all I know is 241s can flow good with a good port job if you search 241 vs 243 a guy on here had his set ported and they flowed intake side 339cfm @ 650 lift
Old 02-20-2009, 02:59 PM
ChevyRyda99LS1's Avatar
I ported my stockers and changed the valves worked out fine for me had a guy in fresno do them I forgot his name
SOMbitch's Avatar
Yes. Upstate NY........
Old 02-20-2009, 03:06 PM
SOMbitch's Avatar
Never seen anything close to 339 in a OEM cathedral port head
Most start backing up much over .600.
Don't believe everything you read.......
Old 02-20-2009, 03:19 PM
VLANDER005's Avatar
I would consider mailing them just about anywhere. Anyone know what valves I should go with? Any one valve combination better than the other?
Old 02-20-2009, 04:42 PM
ZMONSTER!'s Avatar
Did you use the same guy that nate uses?
Old 02-20-2009, 05:30 PM
VLANDER005's Avatar
I don't know who nate is. But I found a speed shop a few hours away that will port and polish my stock ls1 heads with a valve job for 1005 plus tax. Is this a good price? What can I expect for hp gains?
