bolt on cam only lt1, rmps hang around 2k! wtf
Old 02-19-2009, 09:27 PM
sohc19974.6l86's Avatar
Default bolt on cam only lt1, rmps hang around 2k! wtf
it runs good but coming to a stop the car stays at 2k and backfires( pops) untill you completly stop and about 6 seconds later it will come down. anyone know what or why its doin this?
Old 02-19-2009, 09:28 PM
z28rob18's Avatar
do you have a new TB wen i put my new TB on it would hang up as high as 4k u try sprayin it with some lube?
Old 02-19-2009, 09:32 PM
i just had it off today and cleaned it real good, i dont think theres any problems with it.
Old 02-19-2009, 09:33 PM
myltwon's Avatar
you just install the cam?
Old 02-19-2009, 09:40 PM
no, the car has a pcm4less tune...i just bought the car, just trying to go thought it and figure it out. there are no vac or gasket leaks that i know i checked the best i could its got all new sensors plugs and wires coil-icm. i cant figure out what would cause it to hang up....
Old 02-19-2009, 09:46 PM
myltwon's Avatar
vacuum leak or cam installed wrong imo
Old 02-19-2009, 09:47 PM
is there any way i can find a diagram for 96 lt1 vac routing?
or tips on trying to find a leak?
Old 02-19-2009, 09:49 PM
myltwon's Avatar
vacuum gauge and a can of carb cleaner go a long way
shbox.com should have something in that regard
also how is the valve lash?
Old 02-19-2009, 09:52 PM
myltwon's Avatar
well nevermind didn't see the part about the car running good everywhere else, rule out cam timing and valve lash
possibly stuck TB blades or IAC valve
Old 02-19-2009, 09:58 PM
baldes are good and brand new iac.. oh and the car i very hard to start after hot and cool down...
Old 02-19-2009, 10:02 PM
ss.slp.ls1's Avatar
^^^I'd start there...since you said the IAC is brand new.
Old 02-19-2009, 10:03 PM
myltwon's Avatar
also forgot to mention the fan shroud has a vacuum diagram
Old 02-19-2009, 10:06 PM
could i tak it to a shop to get tuned or can they not do nething if its no rite?
Old 02-19-2009, 10:16 PM
ss.slp.ls1's Avatar
Has it always had this problem or did it just occur lately. If it's the latter, tuning it won't address the actual problem.
Old 02-19-2009, 10:21 PM
myltwon's Avatar
sounds like he bought it that way
maybe throttle cable is binding
