1993 Lt1?
Old 02-20-2009, 12:44 AM
93blacktransam's Avatar
Default 1993 Lt1?
guys i have a 1993 camaro z28 ...can yall tell me everyhitng about it such as....the transmossion ..whats different on them than the older 84 85 ect...just anything i neeed to know...
it has lt4 conversion ....edelbrock headers msd ignition pcmforlesstune k&n cai 3.73s shift kit and 30lbs injectors...is this a pretty good setup wat should ibe putting down and what else do i need to get .......
Need pros and cons on everyhting lol..
Old 02-20-2009, 12:51 AM
ss.slp.ls1's Avatar
Look here for specifics of a LT1 4th gen.
https://ls1tech.com/forums/lt1-lt4-m...ewbie-faq.html
There are some notable differences with a '93 Fbody and a '94-'97 Fbody.
The '93 is has no MAF sensor and runs in Speed Density. The '93 A4 tranny is a 4L60, not a 4L60E, meaning that it is not computer controlled, it has a TV cable. The '93 M6 tranny is a T56 with slightly different gears that a T56 found in a '94-'97 Fbody T56. The '93 oil pressure sensor is located right above the oil filter, unlike the later '94-'97 where it is located on the tob of the block in the rear on the drivers side. The intake is unique to the '93 where the fuel rail cross over is in the back, not the front, making the fuel feed lines unique as well. Other than that, nothing else comes to mind.
Old 02-20-2009, 12:55 AM
pmbmax's Avatar
A 93 is speed density. and has an PROM and is obd1 computer. Has a 4l60 but not an e that is a good thing (same as 700r4) has detent cable on TB. They are prety good cars i have helped build 2 of these . They dont have a vented opti spark. has a tach filter on coil wire . thats all i can comes to mind.
Old 02-20-2009, 12:58 AM
mikes98z's Avatar
The 4L60/700r4 in the 93 is a 30 spline vs. the older 27 spline.
A good catback and switch to longtubes if you want a little more power...also put a 3200 stall in the trans... should run damn good.
Old 02-20-2009, 01:01 AM
$O$OE's Avatar
any reason why a 4l60 is a good thing compared to the Electronic one? i thought about changing my 4l60 and making it electronic..
Old 02-20-2009, 01:28 AM
gregrob's Avatar
http://speeddensity.org/showthread.php?t=679
Old 02-20-2009, 09:39 AM
ss.slp.ls1's Avatar
I guess because you won't have any computer controlled related problems. But by that same reasoning, a T56 will own all.
Old 02-20-2009, 11:16 AM
pmbmax's Avatar
This is from my own experance when you start making over the 500 hp mark if you turn the pressure up to save the clutches the timing gets off. in third gear you have to release the 2/4 band and at the same time apply the 3/4 clutch pack. all has to be at the same time if not the band releases to soon a flash in rpms the clutch to soon bind at shift. with an E all of this is done with a computer controlled valves. with a plane 700r4/4l60e you can go with a full manual valve body, and all is done with valves. Some will say get this guy to build it and it wont and we have had X number of guys use our transmisions and this dont happen. It may not at first but after a little wear it will . just ask the fast guys not the trans guys. I dont want to make tranny guys mad but it seems the old trans works better. And i had all these problems a few years back so they may have re invented the wheel and i just never got to use it.
Old 02-20-2009, 12:23 PM
myltwon's Avatar
also 93's have a different fuel rail and 22# injectors
Old 02-20-2009, 06:21 PM
Formula350's Avatar
*cries*
I think this is the 3rd or 4th thread of just 09
I can't list all the differences anymore, I'm burnt out. You'll just have to do an advances search in the LT1-LT4 subforum and read the thousand or 2 threads listing the differences.
Old 02-21-2009, 12:12 AM
93TAJ.C.'s Avatar
HAHA thats sad but true ^^^
Old 02-21-2009, 06:10 AM
gregrob's Avatar
Originally Posted by Formula350
*cries*
Or just click the link I posted....
Old 02-21-2009, 10:18 AM
sepno77's Avatar
the 93 also cam w/ forged rods as stated in the "How to Rebuild Small-Block Chevy Lt1/Lt4 Engines" book
Old 02-21-2009, 10:52 AM
James Montigny's Avatar
As did every other Lt1.
The 93s simply had an older design, they started using (stronger) powdered metal rods in later production years.
Quick Reply: 1993 Lt1?
