These valve springs on stock lifters?
Looking at these to replace my stock 02 33k mile springs:
http://www.sdpc2000.com/product/SDL1...S1Setof16.aspx
Is that the best price going on these or an equal?
Will be running the stock cam with Comp 1.85's ~ .550 lift. I read posts about possible float if you don't change the springs.
Thanks for the help!
LS1Tech Sponsor
will work fine on stock lifters not a prob. Did you notice ANY noise from them though before you stopped running the car? If you did then it would be time to change them (the lifters). Also you can use your stock retainers and locks as they are the same style spring, just have more pressure and better coil bind.
BUT if you want to change to hardened locks/retainers or titanium retainers...
here you go
Hardened Locks
Hardened Retainers
Titanium retainers
Those are just what we have in Comp. We have quite a few different companies that make them, but these are the norm.
here you go
Hardened Locks
Hardened Retainers
Titanium retainers
