Gear Opinion?
Old 02-20-2009, 05:41 PM
MYSTIC-1SC's Avatar
Default Gear Opinion?
I know this subject has been revisited time and time again, but i need some opinions. My car currently has trapped as high as 103 in the 1/8th mile. I still have the factory 2.73 gears with a 26inch tall tire. I plan on doing a cam soon along with the spray, so what would be a good gear choice for this size tire, 3.73 or 3.42. I just want to know what gear will give me room to grow as far as my time and mph. Or should I just go with the 3.73s and chose a taller tire. Just let me know what you guys think.
Old 02-20-2009, 05:49 PM
MattIROC's Avatar
I'd go with 3.42's and stick with the 26's since you are trapping pretty high in the 1/8. Are you doing 1/8 or 1/4 only?
Old 02-20-2009, 10:49 PM
MYSTIC-1SC's Avatar
i am mostly 1/8th, but want the car set up for the quarter.
Old 02-20-2009, 11:20 PM
SOMbitch's Avatar
Well... alot depends on your rpms going through the traps.
Old 02-21-2009, 03:04 PM
MYSTIC-1SC's Avatar
yes, i just wanted to know what other people were running gear wise with a car that was caple of mid to high 10s and trapping a 103 mph in the 1/8th. I just need some opinions. If 3.73s would be good, or the 3.42s with my current 26inch tall tire setup.
Old 02-21-2009, 03:10 PM
SMOKNSS's Avatar
I would do 3.73s and just play with the tire size if thats what you desire. There are mostly 1/8th mile tracks around here and most of the 4th gens there run 3.73s for both 1/4 mile and 1/8 mile. So I would say do the 3.73s and then if you decide later you would rather run 1/4 mile switch to 28 or even 30 inch tire, if more gear is needed, nvere heard any complaints from guys around here with 4L60Es and 3.73s on either track.
Old 02-21-2009, 07:02 PM
Elliott's94Z's Avatar
3.73's
Old 02-21-2009, 11:41 PM
jetlag's Avatar
I went with 3.50s.
Old 02-22-2009, 01:06 PM
MYSTIC-1SC's Avatar
thanks for the help guys. anyone else?
