LM1 exhaust clamp
LM1 exhaust clamp
i know the best way is to use the O2 bung in the header, but have many of you used this with much luck ?
zoom Innovate Exhaust Clamp Wideband Sensor Accs
Venturi-effect, tapped exhaust clamp for obtaining accurate lambda measurements in non-cat autos or other engines
LOL Innovate. NOTHING I ever bought from them worked worth a ****.
Theres my opinion. $600+ in equipment, shipping it back and fourth for repair all sold on ebay for $120. Thats 8 months after initial purchase.
Clearly experiences will differ.
I have used my LM-1 for years with positive results. This winter I picked up the exhaust clamp. My tuners have always used their clamp with their software. The Innovative clamp is just that, a clamp which you thread your O2 sensor into, so it should be just as accurate.
Moderator
It's just a keeper widget, I use a piece of coat hanger
wire myself. If you want to look like a pro then you may
go for the shiny store-bought'n but there's plenty of ways
to cobble up something just as functional.
I have had one for quite a while , works great on some exhausts and others with big exhaust tips that step up tend to suffer from reversion and throw off the readings at idle and low rpm.
at criuse and WOT it works fine giving the same readings as a second unit in a front o2 bung without cats.
