Suspension & Brakes - Lowering with TD's
View Full Version : Lowering with TD's
BlackLS199
02-21-2009, 09:49 AM
Ok here's the deal plan on lowering the car this spring but not sure what route to go seeing how I have TD's. I've done the search thing didn't really find what I wanted. So any help from you guys that have done this with TDs will help. Also I've got the tsp system.
UMI Performance
02-21-2009, 10:29 AM
Our technical rep at UMI (Jerry) runs his front on lowering springs and the rear of stock springs. This gives him the racked look and offers additional clearance with his TSP true duals... its a pretty nice look I think. I run my personal car the same way but don't have true duals. What true duals are you running? What springs are you considering?
BlackLS199
02-21-2009, 11:35 AM
I've got the tsp system as well. I'm not sure what springs I'll be running just yet trying to get a feel of what is workin best for what i've got. You would by chance have a photo of your car or Jerry's would ya. Would like to see how much clearance there is.
UMI Performance
02-21-2009, 11:46 AM
Let me look around and I will let you know, there should be one somewhere on one of my computers.
BlackLS199
02-21-2009, 01:10 PM
Thanks ! I appreciate it, I wasn't having much luck with search on finding pics.
BlackLS199
02-21-2009, 07:30 PM
anyone else?
azredbird
02-23-2009, 12:21 AM
No problems here. I am using Sam Strano springs front and back with my custom fabricated true duals with an X.
BlackLS199
02-23-2009, 09:33 AM
What size is your tubing I'm using tsp's 3 inch system thats why I ask. Do you scrape on anything ?
CranMaro99
02-23-2009, 12:58 PM
I have Strano lowering/performance springs and 3 inch TSP true duals.
I daily drive my car in Seattle of all cities, if that tells ya you can get away with it :)
But it ALL depends on how tucked up the true duals are.
BlackLS199
02-23-2009, 04:42 PM
I'm surprised you can get away with that! Do you just lowered in the front or did you go with all four corners?
BlackLS199
02-25-2009, 07:12 PM
anybody got any pics?
UMI Performance
02-25-2009, 07:37 PM
Here is the two best I have where you can see the TSP true duals from the side or back (white Camaro). In these pictures there is a QA1 coil over in the front with QA1 springs. The rear is the factory springs.
Hope these help some!
Ryan
twitchtwice
02-25-2009, 08:04 PM
im lowered about 1.5" all the way around and have a custom 2.5" dual system, with about 3" ground clearance at the lowest point.
azredbird
02-26-2009, 11:21 PM
Ditto!
