what is the best fuel system for my setting ?
guys
i am a little confused between making 3 kind of fuel system
the car is C6 with Stroker 403 F1-C supercharge and i will run smaller then 4.0 pulley
i already got injector 79 LB
so the fuel systems are
1- welbro 255 inside the TANK then 10AN hose to the Bosch 430 then 6 AN to the regulator and to the Fuel rain and back to the tank
2- Welbro 255 inside the tank then 10AN hose to the bosch 430 then 8 AN to the Regulator and the fuel rail ,, back to the tank with 6 AN ( will i lose pressure because i am using 8AN ) ?
3- APS Fuel system ,,, 2 welbro 255 inside the tank ,, but i dont know what is the hoses Size
please lemme know guys ,,, i am seeking for 850 to 900 on wheel
LS1TECH Sponsor
I think you are going the wrong way, trying to run an intank pump in series with a 420.
I have a complete plug-n-play dual intank system for your vehicle & I install it in your tank for you.
Feel free to give me a call if you want more info... I offer night & weekend hours as well.
What you would be looking at is our Stage 3 Street kit Loonies does the pumps.
http://www.nastyperformance.com/Corv...elSystems.html
Nasty Performance Stage 3 Street kit w/ RACETRONIX / LONNIES PERFORMANCE Double Pumper kits - - Will support OVER 1000RWHP 03-08 LS2 LS7 LS3 Corvette Double Pumper - Twin High Output Fuel Pump Kit, Wiring Harness & Hobbs Switch - Fully Assembled & Tested fits in factory fuel tank - Requires your sending unit and drivers side tank for modification $1799.99
Nate
Nate
