Z06 Wheel Issues.
Old 02-21-2009, 02:34 PM
V.B. StreetKiller's Avatar
Default Z06 Wheel Issues.
I have a 02 Z28 and just got some Z06 wheels from a 02 Z06. They came with a 315-35-18 Nitto Drag Radial on the back and a 275-40-17 Nitto drag Radial in the front. I took a hammer to the inner fender to give a little room. I would like to have about the same size sidewall in the front and the back and I dont really want a different size tire in the back, I like the one that is on it. Would a 275-35-17 accomplish the look that I want? The back is still rubbing a litle when im hammer down in a corner. Would I be able to run about a 1/4 inch wheel spacer to fix this problem or would that put my tire into my finder lip? Also are the stock lugs long enough to fit a wheel spacer if I go with that idea?
Old 02-21-2009, 04:04 PM
05MBMLS2's Avatar
First thing you want to do it remove the drag radial from the front...you could go with a 255-40-17 for a slightly smaller sidewall
Old 02-22-2009, 01:57 PM
69TA's Avatar
Is the rear centered with an adjustable PH Bar?
And no on the spacer with stock studs. The factory studs are not threaded to the end and it would be too short.
I wouldn't recommend a spacer unless you went with ARP studs.
Old 02-22-2009, 05:01 PM
LS1nut377's Avatar
well i just went through this kinda smething with my zo6's. i ran a 1/4" spacers for the rear and it seemed to help a little and it looks great, but i still am going to half to do a little room making. if i get to crossed up it rubs slightly.
Old 02-22-2009, 05:17 PM
Its stock suspension. I don't think that it is adjustable.
Don't the rear fenders on Firebirds stick out a bit more than the Camaros?
Old 02-22-2009, 06:57 PM
evil8's Avatar
My 01 Z28 is lowered with Eibach sportlines and the factory ph bar. I use a 3mm spacer and they clear. I am running the F1 Supercar Goodyears that came on my Z06.
Old 02-22-2009, 07:10 PM
RedRallyeZ's Avatar
second on taking the DR off the front
Old 02-23-2009, 04:27 PM
What was the factory Z06 Tire size in the front and rear?
Old 02-23-2009, 04:31 PM
NebWS6's Avatar
275/40/17
295/35/18
I believe....Not 100% would have to look it up.
And if you want the same size side wall buy the same tire... I also second moving the DR to the back
Old 02-23-2009, 06:43 PM
what exactly do you mean when you say buy the same tire?
Old 02-23-2009, 09:16 PM
NebWS6's Avatar
sorry....same size tire
