PO442 Wtf????????????
Old 02-21-2009, 05:51 PM
2 fast 2000's Avatar
Default PO442 Wtf????????????
Okay I know some of you computer guru's can help me out. I know this is Evap control leak.......right? Other than the gas cap maybe setting this off. Where else do I need to look to fix this problem? Intake/egr? If anybody can help me out in pointing me in the right direction I would really be grateful!
Old 02-21-2009, 08:11 PM
bustac's Avatar
Default Dtc
Not sure this...http://www.obd-codes.com/trouble_cod...cted-small.php might help...
Old 02-21-2009, 09:36 PM
simonsez's Avatar
Diagnosis over the internet is shooting in the dark...that being said. If the fuel cap is tight and the filler neck where the fuel cap o-ring meets the neck looks to be free of nicks and rust free, I would replace the EVAP vent solenoid. Let's just say that I see these on all Gm vehicles every day, and they haven't improved them a bit from your 2000. Job security I say...
Old 02-21-2009, 09:43 PM
FiredUpZ28's Avatar
smoke test if you wanna replace the cause and not just throw parts at it.
Old 02-23-2009, 05:14 PM
Thanks guys! FiredupZ28 how do I do a smoke test? Tools to do this with and where do I hook this test up at?
Old 02-23-2009, 05:41 PM
2001NBMZ28's Avatar
Yeah smoke test is the way to go since P0442 is for a small leak somewhere. Friend of mine had the same code and that's how they found it. He had a shop do it, once found the repair was easy.
Quick Reply: PO442 Wtf????????????
