No!! Why is my heater/ac only blowing through the top dash and floor??
I was changing out an emission vacuum line(the decently long one that runs under the throttle body) and for some reason some time after that my ac/heater only blows air through the top upper dash and floor. What do I do to fix this??
look at the vacuum line next to your ecm with the check valve in it. if its broke or has a hole. it can be that if not follow the line going down to the vacuum storage canister make sure everything is connected. other than that could be ur controls or vacuum lines back there.
my car did this to me like 2 weeks ago. I got scared, I thougt my controls had taken a ****. I got to school and I moved the switch again and it worked.
no problems since. :crossfingers:
