Need some help please!
Old 10-13-2003, 06:24 PM
kmdracer's Avatar
Default Need some help please!
I forgot that my window was open the other day at work. Of course, it rained almost all day! Anyway, I wet vac'd the water out, and this weekend, I removed the seats and steam cleaned the carpet. It's now cleaner than it was when I bought the car, but it smells. Strongly! Any suggestions on what to do about the smell? Would baking soda work to get rid of it? Thanks, Kevin D.
PS, this is on the '99, neutral/tan carpet.
Old 10-13-2003, 08:38 PM
wrencher
wrencher's Avatar
Default Re: Need some help please!
I would remove the carpet & jute backing .
You might fabreeze the **** out of it but I'd prolly replace them.
Maybe sampoo it out of car & you can get the mildew out?
Once it gets into the jute backing though it is tough.
Good luck!
Old 10-13-2003, 09:44 PM
do0dfromcali's Avatar
I used carpet cleaner with annonmia (sp?)I just sprayed the **** out of my carpet and then let it sit for 3 days in the garage with the windows open. Now everything smells fine
Old 10-13-2003, 11:06 PM
Cheatin' Chad's Avatar
Whoooo, ammonia smells like cat **** last time I checked.
I have had good experiences with Fabreeze and Ozium. If that doesn't work try the ammonia like doodfromcali says. I haven't tried it but it might work.
Old 10-14-2003, 05:03 PM
weasel_ss's Avatar
Be careful loading your carpet up with Fabreeze. If you use a lot of it each time your car gets heated up by the sun, the Fabreeze will form a cloudy film on your windows..
Old 10-14-2003, 06:17 PM
Mark IXZD 150's Avatar
Buy a new carpet and underlayment. It's really the only sure way.
Old 10-14-2003, 08:57 PM
wrencher
wrencher's Avatar
Speed inc sells the light weight carpet if your looking to trim the car down a little.
Quick Reply: Need some help please!
