New LS1 Owners - Newbie Tech - ls2 clutch????
View Full Version : ls2 clutch????
00TAM6
02-23-2009, 01:37 PM
where can i get the cheapest ls2 clutch/flywheel?? should i go for a ls7 clutch or a ls2 clutch with just a cut out and a air filter.. i talked to a couple of my friends and they said i should just go with ls2 clutch with the mods that i have. let me know you opinions thanks..
Scoggin Dickey
02-23-2009, 01:46 PM
You're after the LS7 clutch kit. $459.99 and it has free shipping right now.
KCRickSS
02-23-2009, 02:16 PM
+1 for the LS7 clutch...its been great for me. It totally feels stock and handles my "modest" power adders with no problems at all - not a hint of slip ever for me.
Couple of comments - don't use any shims. The pedal will start out REALLY close to the floor but my pedal came up on its own and now is very stock-like (middle of pedal engagement).
Also, I would recommend replacing the slave cylinder while you have the clutch out. The LS7 was my 3rd clutch - stock, then a Spec 3 that crapped out after 10k with new slave; then the LS7. Since the Spec 3 slave only had 10K, I thought it would be OK to keep it when the LS7 went in. Mistake. The "new" slave from the Spec 3 started leaking a year after the LS7 went in and I had to replace it. But the LS7 clutch has been great throughout and didn't seem to be affected by the slave leak.
