lowering question
lowering question
I have a 02 firehawk. "idk if they came stock lowered". Anyways, Besides lowering coils, must i change anything else out?? I looked under my ride briefly and it appears i have upgrades shocks. I dont know if they came with the "slp" option or not tho. Anyways. I only wanta lower the rear about an inch and the front .75 to an inch. Any ideas would be great?
thanks guys
thanks guys
theres some basic pics of how it is now.
Well i wanta lower it. But im not sure what kit will work. It appears my cars already lower then most other cars. If it does have the slp option on it then its about an inch lower then stock. I know most lowering springs say it'll lower it an inch from "stock". So i don wanta waste my money on something i already have lol.
thanks guys
thanks guys
The only thing required is springs to lower the car. But you'll need a front alignment obviously, and your rear will be off center so you need an adjustable panhard bar to recenter it. And while you can lower on your stock shocks (bilstiens or not) you may not like the way it rides or handles after wards because they were not designed for a lower spring with higher rates.
I have Gound Control adjustable Coil-overs with Strano springs on all 4 corners with SLP Bilsteins for the spring rates. With this set-up you can adjust your ride height to whatever you like at each corner for appearance or to get the most out of your suspension by "corner weighting!" (balancing weight on each tire)
Are you the original owner and if so are your shocks Orange or Yellow ?
If their Orange then you are at stock height
If their Yellow then you have the Billstien Option with Progressive springs and you have approx a 1" drop.
