PCM speeding up car by itself??????
Old 10-13-2003, 09:03 PM
Tim98TA's Avatar
Location: From the Bowels of Hell!!! You want some of me bitch?!?!?!
Default PCM speeding up car by itself??????
When I let off the brake pedal and start to move,the motor suddenly picks up speed by itself. I can let it go and it will get to almost 20mph like that. Now I am running a TH400 and have had all the tranny codes deleted. When I come to a stop, the motor takes a second before it comes down to idle. Even if I put it in neutral and coast to a stop, same thing. I must be completely stopped before it will idle. Is there some sort of speed sensor that is causing it? Can that be adjusted via LS1 Edit?
Tim
Old 10-14-2003, 12:19 PM
Tim98TA's Avatar
Default Re: PCM speeding up car by itself??????
anyone
Bueller
Old 10-14-2003, 01:42 PM
horist's Avatar
not sure if it's the same issue I was having... but after I put my 42lb injectors in (after I tuned PCM for them so the car would run) I was surging down low...
I would come to a stop and RPMs would go up to like 1500 then slowly come back down and either surge up and down (eventually dying) or sometimes it would actually hold the idle...
I corrected this by leaning the car out more (via IFR table, lower kpa values I set leaner than upper), also brought Main VE down to 55% original from 0 to 1200 RPM (used to be 70% original before injectors) ...
now when I come to a stop it drops perfectly to idle (900) and stays there... no more up and down hunting, dying , etc...
Another possibility... maybe you have a small vacuum leak? Letting in unmetered air takes PCM a little time to compenstate? LTRIMs look good?
Old 10-14-2003, 04:27 PM
Tim98TA's Avatar
Have to check LTRIMS. The car idles good, no surging. It drops to idle only when I come to a complete stop. If I let off the brake, and roll maybe 10 feet, it picks up rpm suddenly, not on a gradual climb. I can put it in neutral and coast to a stop, but it still won't go to idle until I'm completely stopped. I would think a vacuum leak would cause it to run at a higher rpm even at idle position.
Old 10-14-2003, 07:55 PM
heavyhitter's Avatar
Try checking your iacs In gear table in edit That or did you play with your P/N delay ?
Old 10-14-2003, 08:09 PM
Tim98TA's Avatar
Would the IAC thing make a difference if it was in gear only and NOT moving?
I don't have Edit. Thunder did the tuning, but I haven't been back for them to look a this yet. I want to try to get an idea of where to look when I do.
Old 10-14-2003, 10:48 PM
joghotrod's Avatar
Hi Tim, Maybe your brake booster is pulling too much vacuum while your car is rolling. When it is stopped it maybe has less load. Who knows? May also be a little person in there messing with it. LOL. Jimmy
Old 10-15-2003, 11:44 AM
Definately, How big is your cam? It may have been over compensated for. Also I see that you have a A3 tranny if the convertor is tight its hard to tune for a good idle.
Old 10-15-2003, 11:57 AM
Tim98TA's Avatar
Well the car idles great, and its a very loos convertor. Cam is somewhat big, I'll check those settings out.
Old 10-15-2003, 12:23 PM
Moderator
jimmyblue's Avatar
There's something about the IAC not settling to
baseline until the car is fully stopped, to keep
the IAC loop from bottoming out & hunting. It sets
a higher value & drops it slowly to the setpoint
after you drop below (whatever speed threshold)?
Old 10-15-2003, 02:57 PM
Colonel's Avatar
Tim, it sounds like the idle air in gear has been raised.
Old 10-15-2003, 03:10 PM
gojo's Avatar
Tim, it does sound like the RAF in Running air is too high.
Reduce RAF values at the temps at which it's doing it. Try -.50 and adjust up or down from there.
Old 10-15-2003, 07:57 PM
Tim98TA's Avatar
Will get that checked out when I go back to Thunder.
Thanks guys.
Tim
