MLS Gasket and Graphite Gaskets
Old 02-23-2009, 08:26 PM
MagnaTransAm0098's Avatar
Default MLS Gasket and Graphite Gaskets
I have 806 heads with the notches...I understand you can not use the new MLS gaskets with these heads. My question is, is it worth welding the notches and resurfacing to use the MLS's or just put the graphite ones on and forget about it? Basically like a ratio welding and MLS vs not welding and graphite.
Thanks in advance
Old 02-23-2009, 08:34 PM
themack56's Avatar
graphite and forget about it
Old 02-24-2009, 12:28 PM
EVIL z28's Avatar
Use the graphite. It will be alot cheaper than to weld and resurface. The graphite isn't a bad gasket its just harder to clean off.
Old 02-24-2009, 01:58 PM
LS1Tech Sponsor
Beau@SDPC's Avatar
Use these....GTP241S1 and you dont have to worry about no stinkin notches
otherwise ^^^what they all said.
