After heads/intake isntall on 99 Firehawk, car has a miss at idle/low speed
Old 02-13-2003, 02:03 PM
C4VetteLS1's Avatar
Default After heads/intake isntall on 99 Firehawk, car has a miss at idle/low speed
Installed 224 cam, absolute speed 2x heads, ls6 intake, underdrive pulley, slp headers (o2 sims), hardened pushrods, etc.
when you first fire the car up it runs smooth and quiet, after about 2 miles of driving you can feel the miss in the car (almost like it has a huge cam) and when accelerating from a stop you can really feel the miss.
Plugs, plugwires, injector wires all look good. I dont see anything not hooked up. Its been missing since the heads/cam install.
Old 02-13-2003, 03:10 PM
Malicious's Avatar
Default Re: After heads/intake isntall on 99 Firehawk, car has a miss at idle/low speed
Probably need to ATAP it. Maybe a fuel related issue?
Old 02-13-2003, 03:24 PM
Classic's Avatar
Do you have an auto or a M6? You probably just need tunning.
Old 02-13-2003, 06:54 PM
H82BBad's Avatar
Cheack and make sure your ground wires on the back of the head are good and tight.
Old 02-15-2003, 09:08 AM
mike m's Avatar
what pulley did you use, i have heard of pulleys causing a miss. i believe it was an slp pulley that caused the miss on jfm's car, but his miss was up top at around 5500 rpm. he switched to an ASP pulley and it went away.
<small>[ February 15, 2003, 09:13 AM: Message edited by: mike m ]</small>
Old 02-15-2003, 09:24 AM
7 Second Club
Phil99vette's Avatar
Double check the plug gap....My car had a miss after I installed H & C and found one plug was way off.
Phillip
