enough exhaust?
Old 02-24-2009, 07:57 AM
trey1010's Avatar
Default enough exhaust?
i have a 99 trans am m6 with a lid fra and headers. i am wanting to run dual straight pipes back right before the rear axle and was wondern if this would create enough backpressure for my car? also will this make it quite a bit quieter then what my headers with turndowns is now? thanks
Old 02-24-2009, 08:36 AM
IWGF's Avatar
Yeah that'd work. That's what I'm running.
Old 02-24-2009, 08:44 AM
teke184's Avatar
back pressure is a myth for the most part.
true duals will work great and quiet the car down considerably.
Old 02-24-2009, 09:52 AM
Flaring Afro's Avatar
^ not really a myth. theres a reason why exotics use variable exhausts. our engines are big though so it isnt as affected as much. if you have a 2.5 v6 and run with open headers you will have a huge noticeable low end decrease....
Old 02-24-2009, 10:35 AM
01ssreda4's Avatar
^^^check the true dual sticky at the top of the page....
