What could be wrong with my car?
Old 10-13-2003, 11:00 PM
WICKED SS's Avatar
Default What could be wrong with my car?
Well I just got my car tuned a few days ago and sprayed about 5 times on the dyno with new spark plugs. And after I left the dyno I raced my friends cammed LS1 just to compare and ever since then my SES light has been on? I figured that, that happens after the cars tuned with ls1 edit????
Well I took the car out for a test drive and n/a everything seemed fine. Then I turn on the switch for the nitrous and do a couple 2 runs. I noticed the last run the car didn’t seem to pull as hard? And a lot of smoke coming out of the car. I pull over and notice the oil dipstick was pushed out a little and oil must of shot out cause it was all over the under part of the hood? Has anyone had anything like this happen to them? I also had a couple other people in the car that added a lot of weight!! The car doesnt seem to run the same so I am gonna take th plugs out and check them, then do a compression test, anything thing else I should check out?
