LS1 Lid conversion
LS1 Lid conversion
What is involved in an LS1 lid conversion on a 95 Camaro? I heard you need to cut the radiator support? All i know I need is the lid base (radiator cover), the lid, and some sort of ducting to go from oval to circle duct. Will my stock LT1 hood close without hitting this? Any info would be sweet because I couldn't find a writeup.
1 Post
I have a 4 inch cowl and without trimming anything, WITH the base, it is still hitting. I was hoping with the cowl, i could run the full setup.
anyways, here is a thread i started on it
https://ls1tech.com/forums/lt1-lt4-m...-lid-swap.html
this instal is NOT difficult at all. if you pay attention to the link provided it will show what needs to be done.i did mine in less time than it took to decide to do it...the GAINS at the track were waayyy worth it gotta thank roadtrip and the merv for the motivation.
http://www.lt1engine.com/tech/ls1-li...k-camaro-hood/
1 Post
I have the base, slp lid, and glasstek 4 inch cowl, and it still hits, so im going to try trimming underneath my hood...
other thought is, maybe trim the core support and drop it down an inch or two to make the whole assembly fit. Idk if anyone has done this?
Several guys have done just that, but then you have issues with how the rad is going to fit as far as it will lay back some more toward the motor. I think the best setup I've seen is a guy T/AKid? who did this in conjunction with a stand up shorter radiator. Thats getting real deeply involved though as you need the new rad, fans and then all the cutting welding to go along with it, I think he then bolted the rad in as the LS1 lower piece is meant to hold a tilter rad. All these reasons are why I gave up on this idea, it seems like its only meant for guys that have Firebird and are going to use a taller Ram Air style hood to clear it. I don't think I've seen a single camaro yet using the stock rad support and any other hood clear both the stock lower and LS1 lid pieces....
1 Post
Don't use the stock LS1 lid base. Just notch out the core support and make your own radiator cover out of aluminum or some other material, to help hold the filter up. I still need to make a tray like that, because right now, my filter's just being held to the lid by a couple of screws going through the lid into the filter seal, in the back. I've been very happy with the lid conversion, but it still rubs on the hood a tiny bit. Nothing to really be worried about though. As for the ducting, just get a 4" to 3.5" rubber coupler off eBay. It's only like $10 and works great.
hey quick question will this pass the visual check for smog? i live in CA and they were trippin off my MOROSO CAI they said it didnt have a CARB # so i had to Show them the paper work.
I am really interested in doing this MOD but i dont want it to cause me problems down the road!
