Help new heads and cam and car wont respond
Old 10-13-2003, 11:16 PM
A Mustang's NightMare's Avatar
Default Help new heads and cam and car wont respond
I just finished putting this stg 2 settup from ARE and the car wont respond when I step on gas.It just revs a little and stops.I also installed 42pound injectors and the 255 walbro fuel pump.I'm crrently running 91 octane.Please guys any suggestions are fine.Thanks
Old 10-13-2003, 11:21 PM
Default Re: Help new heads and cam and car wont respond
And also I havent tune the car
Old 10-14-2003, 06:20 AM
gomer's Avatar
If you installed the 42lb injectors without doing any tuning for them.. that is more than likely your problem.
Old 10-14-2003, 08:32 AM
Restricted User
2001 Pewter WS6's Avatar
Put your old injectors back in until you get the tuning done for the bigger injectors.
Old 10-14-2003, 08:59 AM
I'm doing the tuning this coming monday.Thanks guys.
Old 10-14-2003, 10:01 AM
CHRISPY's Avatar
I wouldnt drive around too much with the 42#'s in the car. You will kill the plugs and possibly hurt the rings.
Change the plugs before you dyno, they will definitely be toast.
Cheers,
Chris
Old 10-14-2003, 11:46 AM
PurEvl's Avatar
you risk gas soaking the motor, listen to chris
Old 10-14-2003, 08:03 PM
I just bought bosch apark plugs and should I go with smaller injectors instead
Old 10-14-2003, 09:21 PM
Beast96Z's Avatar
The injectors can be tuned in to work fine, and the Bosch plugs suck. Buy some NGK TR-55 if you are straight motor or TR-6's if your gunna spray. And don't drive it anymore until it's tuned.
Old 10-15-2003, 08:45 AM
I got those Tr-6's.I'll put them back again.
Old 10-15-2003, 09:29 AM
CHRISPY's Avatar
Dont drive the car till you get in it to drive to the dyno.
Ideally throw in the new plugs when you arrive at the dyno and throw a base tune for the 42#'ers in the car. Then do your pulls and see how everything looks. Doesn't take long to kill a set of plugs with those big injectors
Cheers,
Chris
Old 10-16-2003, 12:12 AM
Cool I really aprecieate all your guys help.Thanks
Old 10-16-2003, 01:05 AM
LS1Tech Sponsor
Slowhawk's Avatar
I'd say put back in the stock injectors,TR6 plugs and change your TNT dry kit to a wet kit.Problems solved.
