4L80, from 4WD to 2WD, what do I need?
Old 02-24-2009, 02:48 PM
LSfan70s's Avatar
Question 4L80, from 4WD to 2WD, what do I need?
Hi guys, I just bought a 6L truck engine with a 4L80 atached to it.
It is 4x4, so what parts do I need to buy to make it 4x2?
Who sell those parts? And who sell them used?
Its for a budget project.
Thanks for any help.
Old 02-24-2009, 05:21 PM
TheLS1Kid's Avatar
You just need a 2WD extension housing.
I have no idea where you can get a used one. Maybe a junk yard?
Old 02-24-2009, 05:40 PM
LSfan70s's Avatar
But I've heard I also need to change something in the internals. I am not sure what is it.
Randy WS6's Avatar
You will need a tail shaft and housing, there all over e-bay ,type in 4l80e
Old 02-24-2009, 08:13 PM
Closed ex-Sponsor Account
tptransmission's Avatar
Don't forget the the two wheel drive has an orifice cup plug in the rear of the case were the 4wd is not orificed. Just drill a .040" hole.
Old 02-25-2009, 05:54 AM
GMCtrk's Avatar
It's a pretty involved swap over I believe and it's said it's easier just to go buy a 2wd trans
Old 02-25-2009, 06:26 AM
forcd ind's Avatar
just curious if the 4 wh trans has a speed sensor ring on the rear output carrier, i thought they used something in the other case for the speedometer
Old 02-25-2009, 08:13 AM
There is a ring on the output carrier, just no sensor. They use the sensor in the T-case. It is not a difficult conversion just a output shaft and case extension plus the orifice in rear plug.
Old 02-25-2009, 12:02 PM
9000th01ss's Avatar
4x4's DO NOT come with a reluctor wheel for the rear speed sensor.
For the swap you need these 4x2 parts:
Output shaft
Tail housing
Speed sensor reluctor wheel
Rear speed sensor
Orificed cup plug
Maybe valve body gaskets, I would get a whole paper and rubber kit (usually comes with the cup plug).
Probably around $400 worth of parts depending on where you get them.
Old 02-25-2009, 03:09 PM
LSfan70s's Avatar
Output shaft
Tail housing
Rear speed sensor
Orificed cup plug
Thanks for the info. I am chacking at ebay.
Old 02-25-2009, 09:34 PM
9000th01ss's Avatar
I'd check the local transmission hardparts supplier, and the small transmission shops, and ask them if they know any hardparts suppliers.
Quick Reply: 4L80, from 4WD to 2WD, what do I need?
