Engine Removal Questions...
Old 02-24-2009, 07:06 PM
W es 6's Avatar
Default Engine Removal Questions...
Long story short, my crank pulley bolt is snapped INSIDE my crankshaft and there is nothing else that I can do for it soooooo I'm pulling the engine and taking the crankshaft to a machine shop. I was just wondering if anyone could point me in the right direction of a good write-up on how to properly pull the engine and/or give me some advice on how to do it. Thanks!
Old 02-24-2009, 08:53 PM
conan's Avatar
Do you have a lift? Or access to a lift. Removing it through the bottom is the easiest way IMHO.
Old 02-24-2009, 08:57 PM
superssport's Avatar
Did you try an ez out on the old bolt. It takes alot of patience and accurate drilling but it can be done. I know from experiance on a ford.
Old 02-24-2009, 09:04 PM
lemons12's Avatar
just start pulling acc. off.. move radiator and stuff out of the way.. unhook everything.. unbolt it from tranny.. pull it from the top..
shouldnt take but about 2-3 hours..
Old 02-24-2009, 09:50 PM
W es 6's Avatar
I do have access to a lift.... I thought that these *almost* couldn't be removed from the top...
Old 02-24-2009, 09:52 PM
fast377's Avatar
You don't even have to take the hood off to take them out the top.
Old 02-24-2009, 09:53 PM
They can come out the top but it is much easier to drop it out the bottom. I have done it both ways and the bottom was easier and took less time. The lift will make it very easy.
Old 02-24-2009, 10:57 PM
conan's Avatar
If you can use a lift drop it through the bottom with the trans on the engine. Take your time and have a buddy help if possible. There are grounds on the back of the heads so watch that while lowering the engine. Here's some pics of mine coming out for some ideas.
http://mycarpics.shutterfly.com/208
http://mycarpics.shutterfly.com/209
http://mycarpics.shutterfly.com/210
http://mycarpics.shutterfly.com/204
http://mycarpics.shutterfly.com/175
http://mycarpics.shutterfly.com/176
Old 02-25-2009, 04:35 PM
lemons12's Avatar
its easy to bring em out of the top...
like i said, not hard at all..
with a lift, i would drop it.. if you dont have a lift, pull it..
