Car jerks! Any takers?
So I start driving my car and everything is fine. When I let off the gas the car starts jerking. To stop the car from jerking I either give it more gas or push in the clutch. Once I do this its fine until I let off again.
This has been going on for about 4 months and its driving me insane. Any input would help. Thanks in advance!!!
Does the drive line clunk when you put it in gear or let out the clutch? Put it on level ground, block the wheels so you can crawl under safely with it in neutral. Then grab the drive line and try to turn it back and forth by hand. If you have slop in the motion you could have a bad U joint.
When you put in the clutch it releaves the strain on the driveline. And that would also pertain to a bad motor or trans mount as suggested by LS6427 above. Drivetrain problem.
