Got the 383 in, and from the top!!!
I finally got the 383 in, and it was a PITA to pull the old 350 out. Took the most time to get the tranny unhooked from the block, so when I put it back in, the tranny and motor went in together. Got it back in, and only took about half an hour.
Nah you don't need a lift
I usually grab it by taking a section of seat belt and tying it to the core support, on each side of the plastic radiator support. It works good. In those pics the fascia still happened to be off the car from painting the engine bay so I got it from the frame horns with a chain.
Location: Born/Raised North East, MD Lived in VA, NC, MI Back in Yorktown, Va
1 Post
you have to pull the entire front end off your car to do it like that. the top you have to unhook all the same amount of stuff. but through the bottom you have to mess with your brake lines also. sorry ive been through this with a million people and im prolly one of a few people who think pulling from the top is way easier.
Yeah. It's been beat to death. You don't need a lift to go out the bottom. You don't even need a cherry picker, you can use two floor jacks and big jack stands. Anyone who want's to argue that pulling the motor out the top of a 4th gen is easier than dropping it out the bottom...
