New LS1 Owners - Newbie Tech - lowering my 2000 z28
respectmyfresh
02-24-2009, 10:20 PM
newb here, i want to lower my camaro not really for performance, but to get rid of that ugly wheel gap, dont know where to start,dont want to spend a lot of money either, what do i need:eyes:
refer to link below
http://www.ls1tech.com/forums/suspension-brakes/422236-lowering-guide-newbies.html
respectmyfresh
02-24-2009, 10:29 PM
thanks dude
moosezloose
02-26-2009, 07:29 PM
Eibach prokit
chavez885
02-26-2009, 08:20 PM
http://www.stranoparts.com/partdetails.php?PartID=19&CategoryID=113&ModelID=7
These are on back order often...:nod:
BlackBeautyWS6
03-01-2009, 09:09 PM
I went with Eibach. Looks pretty nice to me.
SOMbitch
03-02-2009, 01:16 PM
Eibach prokit
^^^^NOOOOOOOOOOO:eyes:
Just go search the suspension section........
blk/slvr02ss
03-02-2009, 01:28 PM
Summit Racing has lowering spring kit's for $125.95 and they set the car just right and ride great.
TAtoad
03-02-2009, 01:39 PM
a dude i know got the summitsprings for his ws6. perfect drop i think. not overdone
Wesmanw02
03-02-2009, 01:46 PM
Remember the lowering springs themselves are only half the job.
The other half is correcting the front camber, differential pinion angle, and panhard rod adjustment (in which case you need an aftermarket adjustable one).
All those things need to be corrected after you lower the car.
TXZ28LS1
03-02-2009, 06:06 PM
i am looking at lowering my car as well. im looking into BMR or hotchkis.
SOMbitch
03-02-2009, 06:14 PM
They are rebranded Eiebachs. You REALLY need to do shocks at the SAME time. The factory DeCrappys can't even damp stock springs much less ones with less travel:nod:
Eibach msakes some OK stuff for some cars but NOT f-bods.. Their rates are WAY to soft in back and they have sagging issues. Less travel + low rates = lots of time on the bumpstops....
The drop looks good but ride SUCKS... There are springs out there there that look good AND ride pretty well too:D
Just research well before you buy.......:chug:
spaz1
03-02-2009, 06:21 PM
I had the pro kit in mine.Ride was good.
badazz99ta
03-02-2009, 06:41 PM
strano springs coupled with koni shocks and an adjustable panhard bar. and if you cant afford konis, bilsteins would be the next best thing, although not designed for lowering springs, they are 100x better than the deshitstains.
chavez885
03-02-2009, 08:03 PM
Actually....the LT1 prokit does not have these issues. But the LS1 kit does as well as any of the sportlines.
nemss1
03-02-2009, 09:33 PM
also look into the heater hose mod. koni shocks also have a lower perch which brings the front down
SOMbitch
03-03-2009, 01:16 PM
I will respectfully disagree with you.....Yes the LT1's run a little more rate probably because they were designed with the heavier LT block in mind they are still not ideal rates IMO. Better than the LS kits yes but still could be improved upon.......
PhantomR/T
03-03-2009, 02:28 PM
I dont mind the prolines at all. I have competition engineering 3 way adj. rear shocks and tokico's up front. I also have adj panhard bar, LCA relocation brackets and adj. LCA's.
Just having the spring/shock combo I have now wasn't bad at ALL by itself. I have lowered almost every vehicle I have ever owned
