Ford 8.8 Rear buildup questions
Old 02-25-2009, 09:13 AM
dcmercury2's Avatar
Default Ford 8.8 Rear buildup questions
I have an 8.8 ford rear in my 00 camaro, As far as i know it is stock, it came with the car, it has 3.73 gears. I want to know what parts i can get for it so i can beef it up. I currently put out 480rwhp and 430rwtq, i drive the car daily and am getting a rear end vibration. I was told that i need to rebuild the rear, but since i dont know anything about ford rears i wouldnt know what to get. I would like it to remain streetable and be able to handle the power with no problems. I was thinkin of movin up to 4.10 gears. Any suggestions and pricing on parts?
Old 02-25-2009, 01:36 PM
ElkySS's Avatar
you could put on a girdle, upgraded axles, better diff, weld the tubes, as far as basic stuff, the 8.8 really isnt all that different from a 7.5. just bigger
Old 02-25-2009, 06:14 PM
brokenbird's Avatar
and its alot stronger than a 7.5 im ordering one as soon as it gets finished up but axels and a girdle should do it
Old 02-25-2009, 06:23 PM
SLawson86's Avatar
mine is getting built as we speak. narrowed 2.5 inches, 9in big bearing ends, spool, 31 spline axles, 4.10's, welded tubes... good friend of mine owed me a few favors, so he supplied the rear and the fabrication. all i have done is bought parts, my total is about 600.00 not including bearings. (actually i came out of pocket 200.00, i traded out for 400.00 of it.)
Old 02-25-2009, 06:46 PM
DarkFormula's Avatar
I have one I just bought for my car. Welded and sleeved tubes, Ford Racing Tru-Trac and gears, and a girdle. I'm upgrading to Moser axles (28 spline) and an ARP carrier bolt.
Old 02-25-2009, 07:38 PM
dudeman's Avatar
how are you guys putting it in the car? welding a t/a bracket, four link, or ladder bar setup?
i have been thinking about this. i have a guy that fabs rear ends. said he has a jig already. can you guys give more details of what you had done, maybe some pics if you got them?
Old 02-25-2009, 07:58 PM
I just bought mine with a four-link setup out of a 4th Gen drag car. I have a fabricator doing a TA mount.
Old 02-25-2009, 08:07 PM
dudeman's Avatar
do you have a pic of the four link? or explain that please.
Old 02-25-2009, 08:20 PM
https://ls1tech.com/forums/lsx-parts...en-f-body.html
Old 02-25-2009, 09:17 PM
Jawsgear's Avatar
Man going through all that work and still having an 8.8 just does not seem worth all the effort. Cool concept I suppose. Upgrade Options, Girdle, 9" Ends, Axle Shafts, Eaton or Truetrac, 1350 Pinion Yoke are what I would recommend. let me know if we can help you out.
Jeff
Old 02-25-2009, 09:31 PM
Me or him? I picked it up for $650 and just need the TA mounts. I thought it to be a killer deal.
Old 02-25-2009, 09:54 PM
dudeman's Avatar
Jeff
you have these parts?
Old 02-25-2009, 11:02 PM
brokenbird's Avatar
im getting mine form a member here by the name of cam and he makes a tq arm mount and he dose a nice job but if it breaks im going with a 4 link set up but he said i shouldnt be able to break the tq arm mount so im going to give it hell at the track when i get it
Old 02-26-2009, 03:03 PM
Is his screen name cam? Is this a bolt-on piece to the 8.8?
Old 02-26-2009, 04:44 PM
SLP4CamaroSS's Avatar
you can get the ta mount from carrier if i spelled it right its like $150
Old 02-26-2009, 05:14 PM
Formerly darynC-10/23/10
Daryn's Avatar
^^^ its currie i think
the 8.8 is a very good upgrade over the 7.5 not has tough as a 9'' but its still a very good upgrade nonetheless.
Old 02-26-2009, 06:28 PM
Rychen's Avatar
myself coming from a mustang background cannot understand putting an 8.8 in an F body, they break under stock HP output from mustangs and an LS1 puts out a lot more power.
yes they can be "beefed up" but so can a 10 bolt.
if you go to mustang sites you see the same comments made about the 8.8 as everyone here makes on the 10 bolt.
just makes me laugh when I read that someone is installing an 8.8 in their F body.
no offense to anyone so please don't take my comment the wrong way.
more power to ya.
Old 02-26-2009, 08:36 PM
Tell me when a 10-bolt can run in the 8s like the 8.8 can and we'll talk.
Anyone have a link to the TA mount?
Old 02-27-2009, 02:47 AM
Rychen's Avatar
Don't get all butt hurt and snippy you can talk to yourself, I just don't understand spending the money on one when the same money can be spent on something better is all.
just my $0.02 take it FWIW good luck with the build.
Old 02-27-2009, 05:42 AM
Well, I like your Formula.
Quick Reply: Ford 8.8 Rear buildup questions
