LS2 chain?
Actually, at this point in time the chains are the same part. The newer LS2 chain is now the replacement for all earlier LS1/LS6 motors. It will run on stock gears, but you need to ensure they are not worn so the chain will disengage properly from the sprocket as it spins.
