adjustable rockers if mill heads
Old 02-25-2009, 08:12 PM
bad toys's Avatar
Default adjustable rockers if mill heads
if i mill my heads .010 and put a .040 head gasket .wont i have to use adjustable rockers or i guess i could use diff lenth pushrods ,since there would probably to much lifter preload
thanks
Old 02-25-2009, 08:18 PM
SweetS10V8's Avatar
I dont think there will be too much with a change of .020-.025" total... assuming stock parts to start.
Old 02-25-2009, 11:18 PM
'02 WS6's Avatar
Stock rockers can still be used but you may need different size pushrods
Old 02-26-2009, 08:35 AM
Sigforty's Avatar
You could change the pushrods, or shim the rockers. It all depends on how close everything is when you seal it up. If you are running stock lifters, they like a little more preload than say Morels.
