Hurry need help quick!!!!!
Old 02-25-2009, 08:40 PM
stonemonk's Avatar
Default Hurry need help quick!!!!!
quick, i have air to the cylinder and im changing my valve springs, i have the prc dual spring kit and am just pulled off the first valve seal, now i find out that they are different between exhaust and intake and i cant tell any difference between the ones in the prc kit! how will i know which ones go to what they all look the same???? please help fast!
Old 02-25-2009, 09:46 PM
stonemonk's Avatar
o well, i put the cylinder to TDC and shut the air off. Looks like im going to gm tomorrow to buy stock valve seals, is there any draw back to using these?
Old 02-25-2009, 09:50 PM
Nitroused383's Avatar
The aftermarket ones are just viton seals. You do not need a different seal for intake and exhaust. GM apparently uses two different seals but it is not required.
Old 02-25-2009, 10:02 PM
stonemonk's Avatar
are the viton ones any better then the gm ones? or no diff?
Old 02-25-2009, 10:16 PM
5.3LJimmy's Avatar
The viton seals are smaller in diameter to clear the inner spring. They must be used with the dual springs. If you try to use the GM seals it will break the inner spring.
Old 02-25-2009, 10:19 PM
stonemonk's Avatar
hmmm, i see, i take it your normal parts store wouldn't have the viton seals?
Old 02-25-2009, 10:39 PM
The seals that came with your PRC kit are the viton seals you want to use.
Old 02-25-2009, 10:48 PM
BriancWS6's Avatar
Use the seals that came with your spring kit. They are all the same so just grab and go.
Old 02-25-2009, 11:15 PM
stonemonk's Avatar
i beat one up using the wrong size socket to drive it on, so i need one new one.... need to know where to get one quick....
Old 02-27-2009, 08:26 PM
BriancWS6's Avatar
I don't know any local places that would have them. Prolly have to get em from wherever you got them the first time. Several sponsors have them.
