cam checked with cam doctor still need to be degreed?
Restricted User
I got a custom grind cam and it was checked with a cam doctor.... my question is do i still have to degree the cam or can i just line it up dot-to-dot?
if its doctored and u have a non-adjustable chain set, u cant degree it only check it which u have already done, so unless u fit aftermarket adjustable sprockets there isnt much point as u can't degree it anyway.
LS1Tech Premium Sponsor
Agreed, the chain set can still be made wrong too, among other things, that can cause the VE's to happen in different places than where they were intended...even if the camshaft is perfect!
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Thats why I run adjustable sprocket. So many people degree there cams but they run stock chain set?. The key way is cnc milled, no issues there..etc but there are other variables that can make the cam out. Simply you can check it and if it has stock sprockets, deal with it if it is a few degrees out otherwise install a adjustable set and do it the right way like I did
