TH400 robbing hp?
automatics and dyno's are never a good match-i think the converter stall is more of a problem than trans
what other trans are you trying to compare the 400 with-if its a lockup trans, then the lockup trans will show less loss, but do you race with the converter locked up?
if you dyno in lockup mode, make some big HP claims, then run it unlocked, the HP is not going to match the MPH
i have no idea what i just said, lol-i have run quicker times than some cars claiming over 100 RWHP than me, so whats dyno #'s mean anyway
if your using a 400 for strength, and dont care about o/d, i wouldnt worry to much about any small hp diff-a broken trans doesnt get you far
the converter has to match your engine/drivetrain setup, thats where you put the power to the road
The slip from the stall throws the numbers off. The 400 was rumored to lose 42HP on its own, the 350 28HP and the PG 18HP. This goes back to the 70's info. It would be nice to guage them all and know for sure. Maybe a "Clutch Turbo vs Stick", direct drive on the dyno. No High Stall Converter.
LS1Tech Sponsor
All I know it that when it comes to and auto, DYNO # mean nothing and are only usefull for tuning.
But at the track well there the lower # auto is generally the winner. When it comes to Autos use the dyno for tuning and the track to say whos faster.
__________________
thanks for the info and the relief guys, i recently picked up a complete th400 setup and will be using it on a 347 nitrous combo. id like to get it tuned N/A first and make a few N/A passes before introducing my newbe self to a progressive 200shot...
now the combo came with a fuddle 3600 and wonder if itll be sufficient enough with my cam: 249/254? i was thinking of keeping the fuddle for the n20 setup and getting a 5k stall for the N/A fun? also is a proper stall necessary for a dyno tune?
but yes ET is more important to me than dyno numbers.
With my old 6 speed in the GTO I would trap 115. With the new TH400 I'm trapping 1 sec faster on ET and 114.3mph on street tires. I would say I didn't loose much. But I haven't been to the dyno, nor do I really care to go. My old numbers through the six speed are in my sig. I had Greg at FTI build my converter for 4000rpm stall at it's NA power and then when I hit it with 200-250 it will stall between 700-1000rpm higher.
