change the oil
change the oil
Im going to go buy royal purple for my ws6 ram air if its the first time putting full synt oil should there be a problem i dont think it will just want to make sure
well my buddy put royal purple in his ss, and he didnt like it as much as he thought.
he switched to german castrol 0w-30 and likes it, but me i run penzoil platinum 5-30
and i love it.compared to other oils i have used at 3500 miles it looks great.
read the thread about RP vs. M1. M1 is all hype. its the worst oil ever made, and there are oil analysis results to prove it. im not going to get into this argument again.
https://ls1tech.com/forums/pontiac-f...mobil-1-a.html
read the results posted up there, especially the last 2 pages. check out bobistheoilguy.com for even more info. i gave away 10qts of M1 when i learned how bad it was. i would use it in my lawnmower. personally, i use nothing but GC 0w30. penz plat. is a very close 2nd, as ive been hearing very good things about that. amsoil would be tied or above penz. plat., personally.
Mobile 1 is no longer a synthetic oil, like it used to be. Royal purple is a full synthectic at $10 dllrs a quart . Now German Castrol 0w30 that is found at your local Auto Zone is a full sythetic just like Royal Purple but $4 dllrs/Quart cheaper than Royal Purple. I personally run the German Castrol im my 400+rwhp 90 supra and 97 ws6 T/A and change the oil at every 8,000 miles and oil filter at 4,000 miles with Purolator Pure One Filter. Dont believe that just because it says "full Synthetic" on the bottle it is because most of the time they are not. Now German Castrol is Castro Syntec 0w30 and in the back of the bottle its says MADE IN GERMANY thats how you know its Germna Castrol and at Operating temp its like a 30w. Dont let the 0w30 fool you all , well thats just my 2 cents good luck and if you have any question about other oils ill be glad to help...
