LS4 Performance - I need a picture and part number
Ill_Born_ss
02-26-2009, 11:28 AM
Can someone with a 2008 Impala ss Please take a couple of good pictures of the intake manifold and the MAP sensor & location. Also the part number on the MAP sensor. These components are an upgrade from the original 06 version for performance reasons.
ImpSS07
02-26-2009, 12:14 PM
Would it be the same as the 07? or is the 06-07 the same?
Ill_Born_ss
02-26-2009, 12:36 PM
06-07 same need 08-09 it was changed for the 08
mixerda
02-26-2009, 01:03 PM
I thought 05-06 map right behind the TB on intake neck and 07+ map was moved further back for performance reasons, what was changed for the 08's?
Ill_Born_ss
02-26-2009, 01:33 PM
I am unaware of the 07 being moved back from on top of the TB inlet manifold side. With this said the info I have says , the intake and map are changed in 08 for the Impala and the Buick Lacrosse. Also the new map is faster and more reliable at wot and high rpm use.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
