moser 12 bolt whine
moser 12 bolt whine
I installed my moser 12 bolt about 3 weeks ago did the heat cycles and had no noise till i took it to the track and now it whines on decelleration any ideas??
Re: moser 12 bolt whine
3 times i have rebuilt mine, you are not going to get away from it. might as well either invest in a louder stereo or a set of earplugs or a ford 9 inch.
Bigbos
Yea i do have enopugh fliud.
SSaction
Have you takenit down the track yet?
Thanks evil maybe i just have to deal with it
I am using my buddys account dont know password all.
SSaction
I got close to 7000 miles on mine and many many trans brake launches and it doesn't make a peep...I'm running 90w140 oil too....
auto's dont seem as hard on them for whatever reason. my buddys 2000 ss cuts 1.48 60's on motor and his sounds pretty good, mine, i have yet to cut a 1.4 anything and it woulds like im skinning a cat everytime i drive it even after 3 different setups.
mine wines a little at 55 mph...but anything over or under that speed not a peep. I also have the 33 spline with 4.11's. But from what I understand from Mosier the houling is normal with 4.11s and 33 spline. They will all houl a little bit.
8 second mod
Mine made noise all the time. Not bad, but a whine.
I also pulled it apart and talked to my parts guy, He said Moser was Def making a few bucks on there rears. The eaton they used is rated for 350rwhp!! That is it. Be carefull what you pay for. I was told this rear is the best, and as soon as I got traction, It blew and i find out it was a junk rear, put together by Moser. That would explain alot.
Good luck
Good luck
Well knock on wood but my rear has held up to a few 6500+ launches and is quiet as a mouse. no prob, noise, or leaking. ALTHOUGH i did have my boss set up the gears for me when i got it (he runs in the Outlaw class in a 66 chevyII in the high 7's...about 1600rwhp on a 26psi procharger...was out testing it the other day...5.30 @ 135 in the 1/8th )
