help? alternator bracket removal
Old 02-27-2009, 05:04 PM
brynnda's Avatar
Default help? alternator bracket removal
my alternator bracket broke, the cheap *** pot metal crap in the front of the alternator, where the bolt goes into, i removed the alternator and looked around, and im not liking what i see, someone pls tell me this isnt going to be the nightmare i think it is
Old 02-27-2009, 05:14 PM
94Z28rag's Avatar
Not sure exactly what you're looking for, but here are the bolts that need to be removed:
Old 02-27-2009, 05:15 PM
ak95ta's Avatar
Sorry, it's a nightmare. AC, PS, As well as the alternator have to come off.
Old 02-27-2009, 05:30 PM
brynnda's Avatar
the alternator is off, the damn pulley has to come off and the p/s pump too....
Old 02-27-2009, 05:35 PM
ss.slp.ls1's Avatar
Jesus Brynnda, when are you going to learn that if you need any LT1 help, to call me.
There are four bolts total, two that go in the passenger side head, and two that go in the block, see the picture in the link.
http://shbox.com/1/accy_brkt.jpg
Old 02-27-2009, 06:01 PM
brynnda's Avatar
no ****, but to get to them the pwr steering pump has to come off and so does that damn pulley. i was hoping for a running car tonight
Old 02-27-2009, 06:04 PM
ss.slp.ls1's Avatar
You don't have to pull off the pulley to get the pump off, there are little holes in the pulley that allow you to remove the two pws pump mounting bolts. Like I said...ask me for help.
Old 02-27-2009, 06:06 PM
95Banshee's Avatar
The P/S pulley does not have to come off you should be able to access the bolts through the holes in the pulley
Old 02-27-2009, 06:13 PM
brynnda's Avatar
how much you asking for that bird?
Old 02-27-2009, 06:14 PM
brynnda's Avatar
what size are said pos pws bolts?
Old 02-27-2009, 06:15 PM
95Banshee's Avatar
did you break a pice off of it or did u just strip the threads.
Old 02-27-2009, 06:17 PM
95Banshee's Avatar
10,500 For the bird and the bolts are probably 13mm
brynnda's Avatar
broke it, in the pic that street racing jackass linked - the very top where it says "alternator mounting" in yellow, the top right, where the bolt goes in is broken in half, ill see if i can get a pic
Old 02-27-2009, 06:21 PM
brynnda's Avatar
theyre 10 mm BTW
Old 02-27-2009, 06:30 PM
ss.slp.ls1's Avatar
If it was me, yeah, you, not a chance.
theyre 10 mm BTW
Correct.
Old 02-27-2009, 06:38 PM
brynnda's Avatar
Correct.
go to hell jackass
Old 02-27-2009, 06:41 PM
95Banshee's Avatar
To get that bracket off you are going to have to take off the A/C compressor if i rember right.
Old 02-27-2009, 06:42 PM
ss.slp.ls1's Avatar
go to hell jackass
Ouch. Did you get the PS pump off yet?
Old 02-27-2009, 06:43 PM
ss.slp.ls1's Avatar
Yes, AC, PS, Alt, Idler Pulley.
Old 02-27-2009, 06:44 PM
brynnda's Avatar
ps pump is off
Quick Reply: help? alternator bracket removal
