Manual Transmission - Will the MC RST clutch work with an LS2?
Snyper
02-27-2009, 08:20 PM
I know that the LS1 and the LS2 use different flywheels...and I was wondering if the McLeod RST/flywheel would work with my LS2/MN12?...Its a cammed LS2 that ill be hitting with a 150shot in my 350z and I just want a clutch that will hold the power...not to mention ill be going turbo next year so id rather not have to buy twice.
Snyper
02-27-2009, 08:28 PM
Im also stock using a modified version of the stock GTO master cylinder and was wondering if id have an issue with this as well?(not many options for an LS2 powered 350z) "/
Snyper
03-01-2009, 12:14 PM
Billy M
03-03-2009, 10:49 AM
You will need to use a LS-1 style flywheel. The LS-2 flywheels have a recess and the adapter ring will not bolt up correctly. Mcleod flywheel # 460530 will work.
Snyper
03-03-2009, 06:27 PM
The car wont have any starting issues?
Billy M
03-04-2009, 09:53 AM
Nope. Same 168T ring gear.
Snyper
03-06-2009, 09:05 PM
What about the master cyl? Im stuck usiing a stock modified GTO clutch master...will this be good enough? I plan on making around 600whp and plan on tracking the car.
Billy M
03-08-2009, 09:02 AM
The OEM Master if fine. You may need to change the slave from OEM to a McLeod 1373. The Mcleod slave is tunable to get you the .125" air gap that is required.
Snyper
03-12-2009, 12:18 PM
Ok well I bought a new OEM LS1 style slave, braided stainless line and the RST..make me happy Billy haha
Billy M
03-12-2009, 12:33 PM
Let me clarify. Did you buy the master at the firewall or the slave inside the bell?
Snyper
03-12-2009, 10:58 PM
I have a stock modified master out of an 05 GTO made to fit my 350z firewall/pedal(hydraulic internals are stock) going to a braided stainless line going to an LS1 style(brand new) slave inside the bell...going to your work of art. lol
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
