Help. a/f 10.0???
Help. a/f 10.0???
For some reason my car on the dyno today was reading an afr of around 10. It puffed some black smoke midway through the run and then a tad of white at the end. Im assuming this is very bad. When I fix this will I make more power?
I was still able to put a car length racing from a 60ish roll in 3rd to about 90......on a 08 c63 amg immediately after the dyno....somehow it doesnt all equate.
Could there be anything wrong with my motor if I have been running this rich for a while? I havent hooked up the spray yet so dont worry about that part.... what should my a/f be at and how much more power do you think Ill make?
Thanks
Thanks
If the engine is NA (based on your signature, I think it is), you want to get that AFR more into the 12.5-13.0 range. You will most likely make more power. I've gone as lean as 13.2 in search of power on some engines but that requires a lot of care and attention in the tune to really be perfect, staying a bit richer than that number (12.8ish) is much better for most people...it might leave a few (very few) horsepower on the table, but it's less risky.
If you're going to spray a dry shot, then the tune will need some more work to be safe, but if the nitrous will be a wet shot, you can keep the NA tune in a normal NA range, and setup the fuel jet on the nitrous to keep the nitrous afr correct seperately.
Thanks
Thanks
Definitely need to lean it out though either way
I wouldn't go over 12.8 A/F ratio.
Your tune could be total garbage. Do you have someone who can download it from your vehicle and post it up?
The dark smoke is most definitely a rich condition, the white can be any amount of things.
See if you can have someone look at your tune first before jumping to any conclusions though.
Yes and yes, but if you pull the plugs and they look OK I'd say you probably haven't hurt your O2s. If you had it tuned for spray, perhaps the tuner made it way fat to make it more "safe" on the juice? Pretty common as far as I can tell.
-Eagle
-Eagle
Ever get those exhaust leaks fixed?
But now theres a whole new issue.
