Fueling & Injection - Fuel Problems, Help???
InsaneDomestics
02-28-2009, 04:03 PM
I have a 98 Camaro. I started it up and let it warm up for about 5 minutes or so then it started cutting out like it was out of gas, the car died and I havent been able to start it since. Any Ideas?
And Yes It Has Gas In It...
nemss1
02-28-2009, 05:53 PM
check the fuel rail pressure with a fuel pressure gauge. possibly a clogged filter or bad fuel pump
InsaneDomestics
02-28-2009, 05:59 PM
I can push the nob on the fuel rail and nothing comes out, I unhooked my fuel line before the filter and nothing comes out. I have a 99 Camaro and I took the fuel pump off it and put in my 98 and still nothing. I even switched the fuse for fuel pump......Any other ideas?
98Camarod
02-28-2009, 06:03 PM
If there isn't any fuel squirting out when you push the schrader valve in after you have turned the key to the on position, then you have a fuel related issue as to why your car won't start.
When you turn the key, the pump should prime and give you fuel pressure.
InsaneDomestics
03-01-2009, 05:52 AM
Yes I Know Its Fuel Related, Im Just Wondering If I Need To Spend Money On A Pump Or If It Is An Electrical Problem. Im Not Sure Because I Swapped Pumps Already (As Far As I Know It Was Still Good) And Still Nothing, What Fuse Or Fuses Could Cause This, Other Than The Fuel Pump Fuse Of Course.
98Camarod
03-01-2009, 06:51 AM
Not sure, I think there is a fuel pump relay though.
nemss1
03-01-2009, 12:29 PM
^^^there is a fuel pump relay
InsaneDomestics
03-01-2009, 03:06 PM
Where Is The Fuel Pump Realy On A 98 Camaro?
nemss1
03-02-2009, 06:18 AM
think its on the interior on the drivers side behind the kick panel
InsaneDomestics
03-02-2009, 01:55 PM
NOPE, Tried The Relay And Still Nothing. Any Other Suggestion On This One???
nemss1
03-02-2009, 10:01 PM
fuel pump may have taken a crap. happened to mine when i ran it out of gas. do u hear the pump priming when u turn the key?
InsaneDomestics
03-03-2009, 07:04 AM
Nope, All I Hear Is A "Click" I ordered a new pump, it should be here today or tomorrow. Ill let you guys know if that fixed it. I just didnt think it would all the sudden go out like that. We'll see...
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
